Section 24 Latch Block
Marteck
Member
Working on section 24 rev.1 Where do I find the C-1205
latch block attach information? Are the attach holes tapped into the roll bar? This block is listed in Vans
NOTIFICATION 14-05-22 May 22,2014.
The C-1205 is removed and replaced with a C-1205-1 Fastened to the roll bar with two 8-32 AN509 screws.
Jerry
The latch block is part of the finish kit. It appears in section 34. Page 10, fig2.
It all comes together ultimately.:D
DaveH
120485
Thanks Dave,
I really scratched my head on that one, my parts shelf is nearly bare and no latch block. Of course I was looking for something that was not even on the drawing I was working on.
Are the #8 screw holes tapped into the roll bar? Seems kind of
thin for threads, even with the splice straps.
I will just press on then.
Jerry
Those holes, along with all the holes for the rear window will be tapped, again, it's all in section 34. There is more than enough meat there for the tapping process.
Any time you find yourself wondering where some part has vanished to, the parts list in the first section of your plans gives all the parts by number and the kit they will be included in.
Hope this helps
DaveH
