I spoke with a couple tech support people at Van's tomorrow. They acknowledged they are getting some calls about these issues, and they asked me to send photos and any details I could figure out. They have an engineering meeting tomorrow at noon, and plan to discuss this. Here is what I sent them:
Hello Support Folks,
I am building RV-14 #141428. I am working on the new SB 00128 for the longer canopy latch pins, and having issues. I spoke with John and Kevin in tech support this morning, and they asked me to send photos of my issues so you could discuss in the engineering meeting tomorrow. Here goes:
I am working on the Finish kit, so the rear window isn’t yet installed, making access easy to the SB parts. I haven’t installed the vertical canopy pins that go on the canopy side rails yet. But I previously installed the original canopy latch pushrod and torque tube and bell crank angles, and the canopy latch mechanism worked very nicely, locking and unlocking the canopy.
Yesterday, I replaced the canopy pins and bellcrank angles with the new SB parts, and ran into two problems, though they are probably related:
1. When the canopy latch is pulled open far enough to open the canopy, then the right latching pin gets locked in place (kind of like something went over-center) and I can’t close the handle without first pushing the right side pin forward by hand.
2. The right side pin is binding and causing excessive drag when moving the latch handle open and closed. It works OK, though not smoothly or easily, when the canopy is raised. But when the canopy is lowered, and the right side pin is moving forward to engage the holes in the canopy arch, then it binds and is very hard to close the latch. The left side suffers from the same issue, but not as bad as the right.
Below is a photo of the right latching pin in the open position. You can see that the bellcrank geometry is pushing upward on the tail of the pin. That causes the nose of the pin to dip downward, and the sharp shoulder of the pin is catching on the brass bushing in the rollbar, and then it catches, but even worse, on the lip of the hole in the canopy arch. Another photo below shows the hole in the canopy arch, and you can see where the sharp lip on the nose of the pin is digging into the lower edge of that hole. Same thing happens on the left side, but maybe not quite as badly.
I am including a link to two videos below, showing how the mechanism jams in the open position, and how I can clear it by pushing the pin forward with my finger.
The VAF forums are full of similar issues, and people have been enlarging the holes in the canopy arch and/or also the roll bar to compensate, and reshaping the sharp shoulder on the latch pins. I haven’t tried that yet, but it might solve the problem.
Please let me know what you suggest.
So, that's what I sent them. Hopefully the video links copied below will work.
Good luck with the SB!
-Lou
View attachment 115599View attachment 115600
Here is a link to a video showing the right pin stuck in the open position:
View, organize, and share photos and videos with iCloud Photos on the web. Changes will sync across your devices with iCloud.
share.icloud.com
Here is another video showing how I can get it moving again, by pushing the right pin forward with finger pressure:
share.icloud.com
