SB-00002 Screw Size
skajake
Member
I recently got my sb-00002 rudder bracket kit and the instructions say to final drill #19 the holes common to the bracket and the vertical stabilizer spar.
The instructions then say to fasten these together using AN509-8R11 screws, however the screws seem definitively too large to fit through the #19 holes.
I am sure I missed something stupid, but I am hoping someone has an idea.
Thanks!
I haven't received my sb-00002 rudder bracket kit yet, but looking at the specs the AN509-8R11 screws should be 0.164 diameter and the #19 drill should be 0.166 diameter. Can you check each with a caliper?
MJ
Flying RV-12 (180+ hrs and Oshkosh 2019)
Building RV-10
N418MJ
Warren County, OH (I68)
[email protected]
2020 dues paid
My caliper does not go past 2 digits, but the screws measure 0.18 in diameter. Looks like they must have sent me the wrong ones in the kit.
Just did the SB a few days ago and everything worked just as instructed.
