My 8 is showing some motor sag ( alternator pulley is touching lower cowl) after 16 yrs of hanging and 750 hrs. It’s the standard dynafocal Mount with o360a1a engine. I am aware of shortening the alternator belt, but I understand that the lower bolts are a little longer than the upper bolts so that a washer can be added. Is this standard practice and how hard is the procedure? Would it be better to replace all mounts? They still appear to be in good shape from a visual perspective. If a washer is all that is needed, what part number is it?
