The heat muff on my rv8 slides along the exhaust pipe. 750 hrs shows no sign of wear on the pipe. Is it suppose to be fixed, not loose, or is this acceptable?
Mine was loose when installed, and I had to spend a lot of time bending the tabs and enlarging the holes in the muff to make it tight. If it gets loose over time with vibration, I'll replace it with one of the higher quality units.
