Hight high do the mains need to be raised when doing fuel flow test? Standard tires.
D DanBeadle I'm New Here Jun 29, 2023 #1 Hight high do the mains need to be raised when doing fuel flow test? Standard tires.
PhatRV Well Known Member Patron Jun 29, 2023 #2 When I was testing my RV8, I left it at the 3-point attitude and ran the fuel flow test with 5 gallons in each wing.
rv8ch Well Known Member Patron Jun 29, 2023 #3 Easiest way is to find a ditch or hill or some other way to lower the tailwheel to increase the "AoA". I don't recall the recommended angle, but I can say that under power the RV-8 will climb very steeply.
