Setup wt and balance in my Foreflight app. The result was a square box (envelope) with the forward cg on the left vertical axis and the aft cg on the right vertical axis. The bottom horizontal axis was the empty weight (1167#) and the top of the box was 1800#. So I assume that it's not possible to get out of cg without exceeding max GW of 1800#. The baggage limit I entered was 100#. Does anyone else's Foreflight WB envelope look like a square box?
