RV7/9 (maybe 6?) brake upgrade
edhunter
Friend
Ever think the brakes on your RV 7/9 were less than adequate? Especially if you have a fixed cruise prop and tend to land a bit fast? I did in my -9A, and purchased a set of RV14 brakes to use in their place. I bought these from a guy that didn't like the brakes in his -9 either. They definitely improve braking action. Anyway I no longer have the plane and don't need the brakes. Asking $600 for loaded calipers, brackets and rotors. Plug n play swap, no change necessary to master cylinders. Rotors a bit thicker and calipers a bit larger. Picutres show -14 brakes on the left, stock -9 on the right. Located 7W4 in Va.
