RV4 NEW AILERON ALIGNMENT
I replied on your other post where you mentioned the aileron brackets, but to say again, if all was good flying before keep it the same no matter the "mismatch" I see you have concern about the electric trim weight? I put a servo in my L/H aileron, but its forward of the hingeline in the L/E of the aileron as per plans. I did make a flush type tab that is more appealing than the tab behind the aileron per the kit. I would think you could do a simple re-balance and add weight in the L/E steel pipe if needed.
