Are you all using the rivet lengths that Vans calls out? I have not been able to for many, as so many of them are called up like the picture below. Quite short. Easier to drive but then you have to drive them to min thickness to get the right shop head size. The next rivet up puts you just over the right length and makes a shop head that is never at the minimums. I have seen this on the other RVs I built but the 15 seems to be more so. Are you just driving to get the small shop head using the rivet given or are you changing them? I have lots of rivets so I just grab what I need to get a better length.
I know there is a tolerance to the shop head thickness and diameter but why make it so it is always at the minimum. Wonder if there is a reason for them doing it?
