RV12iS Ducati Voltage Regulator
MooneyHack
I'm New Here
Q1) Are there any known alternate voltage regulator part numbers to replace the Ducati P/N 864-395 that are plug and play (and considerably less expensive)?
The Ducati is only putting out 13.4 - 13.6 VDC, and the battery is discharging when loading up the system with the landing lights and keying up the radio. I would expect the VR should be putting supplying between 13.9 and 14.2 VDC.
Q2) What are other folks seeing as normal on their buss voltage?
I have 550 hrs on my original Ducati regulator. I normally see 13.8 volts. I did just order the new B&C replacement, just to be prepared, considering all of the posted failures
