CessnaTPA
It's been suggested I build in the following order below. I'm on step 4 about to mount the engine. For those who have finished what would you suggest or do differently?
1- Finish fuselage, emp, wings+ flaperons.
2- spray fuselage interior
3- install systems (not the avionics). Test fuel lines for leaks.
4 - install landing gear + engine
5- cowling
6- wing fit ( drill torque tubes, trim flaperons and 3/16 for the wing root skins and check “play” moving it back and forth.
7- install tailcone (make sure you have all wires, air lines and cables ready first. Also, there’s a service bulletin for a reinforcement bracelet for the bulkheads.
8- aft window
9 - canopy
5- cowling
8- aft window
9 - canopy
