RV 12is AV-60007 master & both lane switches intermittent green led lights when on. (All led lights are on or all off) All switches work & installed new ignition module.
You'll want to check pin #3 (yellow/green wire) of the connector.. make sure it hasnt backed out. If you dont find anything, then check the other end of that wire -- pin #4 of the Power Module d-sub (the big connector). There is also a splice in the wire with a solder sleeve.. those have been known to be flakey sometimes .. solder not melting fully inside. So check the continuity.. and wiggle that solder sleeve a bit to make sure its good and continuity is 100%... That wire carries the ground to the ignition module for all the LED lights on it.
