RV10 tailcone ELT and Magnetometer question
btbull
I'm New Here
I am building out my tailcone and received Quickbuild wing and fuse two weeks ago. I have been trying to settle on a rough draft plan for locating antennas and magnetometer.
Equipment I will be working with (IFR RV 10):
GPS: Garmin GA-35 WAAS
Comm 1: Comant CI-122
Comm 2: Comant CI-122
Transponder / ADS-B: Comant CI-105
Nav 1 (VOR/LOC/GS): Bob Archer (hidden inside right fiberglass wingtip)
Garmin GHA-15
ELT: Standard 406 MHz whip
GMU-22
FlyLED position lights and leading edge landing lights on each wing.
I have read the discussions on here and have been studying the install manuals. The main question I have is regarding the GMU-22 and ELT antenna.
I am planning to follow manufacturer instructions with the ELT location (top of tailcone, near vertical stabilizer). I would like to install the magnetometer on the steins fuse mount on the f1008 rib in the tailcone.
Has anyone successfully passed an interference test in that configuration?
I think I have a handle on all the other options / requirements.
Any guidance appreciated!
I have my ELT antenna on top of the tailcone and a GMU 44 but it passed without issue and has worked flawlessly for 11years.1779325582493.jpeg
Garmin GHA-15
GMU-22
The magnetometer (either GMU-11 or 22) in a RV-10 is certainly better positioned in the tailcone. No issues, works well. Easily passes the magnetometer interference test. Wingtip also ok it seems.
Great, that simplifies that.
Do either of you have a remote transponder with the antenna back there? Seems like I should be able to fit both comm antennas and the transponder on the fuse without interfering with the GHA15 cone (behind the baggage bulkhead), but considering my options :)
My comm antennas are on the bottom of the fuselage forward and transponder antenna also fuselage rear. I don't have a GHA15.
My remote transponder is on a repurposed Van’s GRT AHRS shelf next to and slightly aft of the Battery on the left. The transponder antenna is on the right side of the battery on the bottom of the tailcone. My #1 Com antenna is on top of the tailcone right behind the baggage bulkhead (the transition between the tailcone and the cabin top and immediately above the battery). I extended the ground plane onto the cabin top with 3 runs of copper foil tape. Com #2 antenna is on the bottom of the right wing under the wing walk area.
