Does anyone out there have the dimensions, drawings, or airflow systems instructions for the RV10 oil cooler turning vane?
Also, has anyone flown their RV10 before and after this modification and if so, what have the temperature drops been?
Many Thanks
Mike
I made mine. Here are some photos.
Carl
Thanks Carl, exactly what I was looking for. What temps do you see with the turning vane in place?I made mine. Here are some photos.
Carl
Don’t yet know.Thanks Carl, exactly what I was looking for. What temps do you see with the turning vane in place?
As I have the thunderbolt with oil squirters I had to use the larger X2007 cooler. It wouldn't fit the stock mount. I decided to use Carls idea and bolt the filter to the firewall. It's all WIP (work in progress).Don’t yet know.
On the first RV-10 I mounted the oil cooler as shown. Never had a oil temp problem but you need to be careful doing this as there fit is tight.
Carl
