RV10 EGT probe replacement
RNB
Sponsor
I suspect that today two EGT probes on my Mattituck built IO540 engine went bad. What data do I need to gather to make sure I order the right probes to replace?
Thank you.
Thank you.
What type of ignition system are you using? 2 going bad at the same time a little coincidental. If it's a G3X system pretty sure they went with the standard probe kit so type of replacement pretty easy to find. Search ACS Garmin G3X EGT thermocouple.
AFS 5600.
Magneto + Surefly
AFS 5600.
Magneto + Surefly
I believe your Surefly has three coil packs, with each serving a pair of opposed cylinders. If, for example, cylinders 1 and 2 simultaneously show elevated EGTs, it is likely you have a bad coil pack. These failures can be triggered by heat, and they can function normally after cooling off. A post landing mag check can reveal the problem. I happen to have this very problem…..
3,5
Erratic and funny low, like half or less, flickering a lot.
Kind of like last time I had one fail...
So to try and answer my own question I'm guessing the steps are
1. ID the engine manufacturer and size of exhaust pipes
2. ID the engine monitoring system. One might be Garmin into a G3x, others might be AFS.
3. Open the cowling and look for product labeling.
Thank you.
Before you start buying parts. Do some troubleshooting. Swap known good ones for suspect ones. (Move them) If the problem does not follow then the probes are fine but if it does not then you are probably looking at a coil pack.
3,5
Does not sound like a coil pack issue, you would see a notable rise in EGT's. Worth doing the check post landing while hot but probably not the issue.
