chris1seto
Active Member
Does anyone have known compatible tire part numbers for the RV10 Beringer wheels?
I had a rough time trying to work out which tires are actually compatible. I eventually came up with:
www.aircraftspruce.com
and
I know these tires say "tube tires" (TT) in the catalog, but there is also no obvious TL option for the same dimensions, at least for the MLG. Even more confusingly, if you look at the Beringer catalog, you will see a mix of TL/TT tires and it seems like some of the part numbers are somewhat mangled (what's up with the "PAB01" style numbers?).
URL: https://www.beringer-aero.com/sites/beringer-aero.com/files/cata_usa.pdf
Reference: page 28
It seems like from the Beringer catalog, the following tire is recommended for the MLG:
"025-501-1 Tire 15x6.00-6" 6PLY Michelin Air TL 15.00 5.30 1950 7.27 3.30 4.00-6/6.00-6" (out of stock at ACS, of course)
and I don't think I even see an option for the the nose gear.
I called Beringer and they said the TT tires will work "if the leak rate is acceptable".
Does anyone know if the tires I originally selected will work? In the Michelin AIR product line, I don't see any obvious matches which are definitely compatible and available. Thanks!
Michelin Air Tire 5.00-5 4Ply 070-308-0 | Aircraft Spruce ®
Michelin Air Tire 5.00-5 4Ply 070-308-0 Michelin® AIR®: The tire for demanding pilots.
Michelin Air Tire 15X6.0-6 6Ply 070-449-0 | Aircraft Spruce ®
Michelin Air Tire 15X6.0-6 6Ply 070-449-0 Michelin® AIR®: The tire for demanding pilots.
Reference: page 28
