220 MPH true air speed on descents...
I remember one day during my phase one testing when I was hurrying back home before dark and the descent was a bit faster than I planned. I was watching the INDICATED airspeed during the descent and moving right along from 10,000 heading down when I realized the TRUE airspeed was touching on 220 MPH at 2300 RPM on my 160 HP O-320 with constant speed Hartzell prop. I talk about some of that experience on this page:
http://www.n2prise.org/rv9a140.htm Be sure and look at the US FLAG picture showing the wear on it due to high speed fllight.
Needless to say, I have not been there again. No flutter that time, but I would have to say I was pushing the envelope without knowing it at the time.
As for the cruising, I spend a lot of time between 10,000 and 13,500 MSL at full power, 2300 RPM, posting 160 MPH TAS leaned to SIX gallons-per-hour with all the EGT's just about even from my carburetor and induction system.
One other thing to note: At 1000 MSL straight and level, 2300 RPM, full throttle produced 193 MPH both times I tried it. The fuel burn rate goes WAY up there, and needless to say, the manifold pressure is way over "square" at 28 inches or more. I spend most of my time cruising at 160 MPH TAS no matter what altitude I fly. Sometimes I pull the power back to 140 MPH at 2300 RPM when I want to fly "slow" and really save gas. I fly the pattern at 100 MPH downwind with no flaps and 80 MPH on the final approach with full flaps.
Jerry K. Thorne
RV-9A N2PZ "Enterprise"
189.6 Hobbs Hours since June 2005
www.n2prise.org
