My RV-8QB fuselage is serial #83507; received 2/17. The twelve bolts were missing from the forward center section, and today I started work on getting them in place. Inserting the bolts fore-to-aft was easy, but trying to get the washers and nuts on the bolts with the access limited by the assembled center section seemed a nightmare. I also do not want to drill the 1" access holes if I can avoid it. It was easier to guide the bolts in from the back side using a flashlight and magnetic stick, and get the nuts and washers on the bolts from the front. Now all twelve bolts, nuts and washers are in place and ready for tightening and final torque. Before I do, I will probably call Van's tomorrow and double check to make sure installing the bolts backwards won't cause a problem. I know from reading this thread that other builders have done it this way, and I already know what I'll do to modify tools to get the job done. It will also be easier to mark the nuts with torque paint when finished. But I thought I'd check here: can anyone think of a reason why I shouldn't do it this way? As far as I can tell, the only "rule" I'm breaking is the traditional "insert bolts from fore to aft". Are there any other clearance issues involved in having the nuts on the front outside of the center section?
(No response here, but checked with Van's; approved)
