MarkSchmitz
Member
I'm starting to mount the main gear legs on my QB fuselage. If I'm reading the manual correctly, I'll eventually need to drill holes in the bottom skins in order to drill the most forward/rearward holes through U-805-1 (outboard wear plate, pre-drilled). Do I have that right? I'm a little reluctant to add holes to my skins. Any suggested alternatives? Otherwise, any advice for positioning and drilling the holes through the skins?
Mark
RV-8, Fuselage
Mark
RV-8, Fuselage
