RV-8 Flap Position Sensor Install
Terry Lutz
Sponsor
I'm going to install a Ray Allen position sensor for my flaps, which I can display on my G3X and use for a specific performance program. I know that the position sensor has a very small travel range, so I'm looking for ideas on how to engage the sensor and flap control arm within that travel range. Any photos would be appreciated!
Here is my setup. I used the ball and socket RC pushrod connectors to make it easy to install and to remove. There was some trial and error of getting the position on the flap arm to ensure the sensor has most of the movement range. The homemade bracket around the flap arm is to provide an easy contraption to test the pushrod end location at the flap[. The slight flexibility of the bracket is to prevent the sensor from overly compressed or extended if you get the initial position wrong.
Here's what I did
Flap Sensor/G3X Intergration
In regards to a wiring schematic, how do the signals from the flap sensor feed to the G3X?
I'm just starting to think about my schematic development and this is a question I've had in the back of my mind.
Any help would be appreciated.
Laird
Flaps sensor wiring
From the G3X IM rev ap, page 498.
See attachment.
Good luck
  • flaps.pdf
Perfect. That's the diagram I was looking for. Guess I just didn't look far enough in the manual. I know, RTFM...
Thanks much.
Laird
