Yaaaaaah now we are getting somewhere!
Taking full advantage of the day off!
20170821_155608 by Jereme Carne, on Flickr
20170821_155608 by Jereme Carne, on Flickrawesome, inching closer day by day
I am happy to see your wing pictures and progress. I have to strip the skins off of my wing for the most part and I can use this page as a visual aid! Have to build one wing all together as well. Thanks for the help!
20170826_165944 by Jereme Carne, on Flickr
20170906_181517 by Jereme Carne, on Flickr
20170910_163430 by Jereme Carne, on Flickr
20170914_193258 by Jereme Carne, on Flickr
20170918_191500 by Jereme Carne, on Flickr
20170827_172917 by Jereme Carne, on Flickr
20170831_174422 by Jereme Carne, on Flickr
20170906_173809 by Jereme Carne, on Flickr
20170909_120803 by Jereme Carne, on Flickr
20170910_163853 by Jereme Carne, on Flickr
20170923_154818 by Jereme Carne, on Flickr
20170923_174926 by Jereme Carne, on Flickr
20170924_162212 by Jereme Carne, on Flickr
20170927_203639 by Jereme Carne, on Flickr
20171004_203045 by Jereme Carne, on Flickr
20171007_125707 by Jereme Carne, on Flickr
20171013_171000 by Jereme Carne, on Flickr
20171013_191604 by Jereme Carne, on Flickr
20171013_191613 by Jereme Carne, on Flickr
20171013_183718 by Jereme Carne, on Flickr
20171014_140643 by Jereme Carne, on Flickr
20171014_151351 by Jereme Carne, on Flickr
20171028_141054 by Jereme Carne, on Flickr
20171022_152741 by Jereme Carne, on Flickr
20171028_202304 by Jereme Carne, on Flickr
20171029_125416 by Jereme Carne, on Flickr
20171029_160048 by Jereme Carne, on Flickr
20171029_162544 by Jereme Carne, on Flickr
20171021_105836 by Jereme Carne, on Flickr
Capture by Jereme Carne, on Flickr
20171112_201551 by Jereme Carne, on Flickr
20171022_152728 by Jereme Carne, on Flickr
20171104_204652 by Jereme Carne, on Flickr
20171119_151323 by Jereme Carne, on Flickr
20171118_174043 by Jereme Carne, on Flickr
20171119_151312 by Jereme Carne, on Flickr
20171119_151337 by Jereme Carne, on Flickr
20171125_143547 by Jereme Carne, on Flickr
20171125_151230 by Jereme Carne, on Flickr
20171125_174251 by Jereme Carne, on Flickr
20171125_174257 by Jereme Carne, on Flickr
20171201_165757 by Jereme Carne, on Flickr
20171202_141004 by Jereme Carne, on Flickr
20171202_140730 by Jereme Carne, on Flickr
20171202_230623 by Jereme Carne, on Flickr
20171203_113655 by Jereme Carne, on Flickr
20171203_124527 by Jereme Carne, on Flickr
20171215_174417 by Jereme Carne, on Flickr
20180103_200548 by Jereme Carne, on Flickr
20180104_202138 by Jereme Carne, on Flickr
20180104_210700 by Jereme Carne, on Flickr
20180303_154142 by Jereme Carne, on Flickr
20180311_123056 by Jereme Carne, on Flickr
20180311_123318 by Jereme Carne, on Flickr
20180311_140850 by Jereme Carne, on Flickr
20180314_180316 by Jereme Carne, on Flickr
20180314_183820 by Jereme Carne, on Flickr
20180314_191926 by Jereme Carne, on Flickr
20180315_183940 by Jereme Carne, on Flickr
20180315_183951 by Jereme Carne, on FlickrYour work really looks super clean. I hope I can match this quality of work whenever my wings show up.
20180323_180951 by Jereme Carne, on Flickr
20180323_212051 by Jereme Carne, on FlickrHow is the riveting on the wing? That is next for me Jereme.
After I drill out all the rivets and start riveting new skins...lol
Kent riveting of the wing has been pretty easy so far. Riveting the leading edges was no problem but I did have someone to help me hold the gun steady. I wouldn't attempt anything close to the tip of the leading edge without someone holding it. Riveting ribs was easy. Riveting the leading edge to the spar was difficult to set the rib to spar rivets but the skin to spar rivets were a breeze with the squeezer. After all the bucking you have had to do for your fuselage it will be no problem at all. I also had a bit of trouble with the tank riveting but I think that was mainly because I couldn't see things since they were covered in gorilla snot!In the next week I'll be doing to top skins using the back rivet method so we will see how I do at that new task.
Thanks Jereme. I have found a person who I think can help me from time to time...![]()
20180324_180037 by Jereme Carne, on Flickr
20180325_154547 by Jereme Carne, on Flickr
20180325_154552 by Jereme Carne, on Flickr
20180327_182057 by Jereme Carne, on Flickr
20180328_211740 by Jereme Carne, on Flickr
20180330_150211 by Jereme Carne, on FlickrSorry to hear the backriveting didn't work for you. It worked fantastically for me, with the right tool and technique! But either way, you win!![]()
The one I have is from cleavland. Link here:
http://www.cleavelandtool.com/mobil...BACK-RIVET-SET/productinfo/4653/#.WsMUuHNlBJc
20180407_135615 by Jereme Carne, on Flickr
20180407_145033 by Jereme Carne, on Flickr
20180409_182718 by Jereme Carne, on Flickr
20180408_150846 by Jereme Carne, on Flickr
20180409_174657 by Jereme Carne, on FlickrIt is so shiny! Very nice work!
20180414_155303 by Jereme Carne, on Flickr
20180415_195334 by Jereme Carne, on Flickr
20180417_180227 by Jereme Carne, on Flickr
20180417_180235 by Jereme Carne, on Flickr
20180417_182130 by Jereme Carne, on FlickrDid you do anything about the pillowing or leave as is? I just finished my right wing and there is minimal on that one but the left LE is a bit more noticeable. I haven't riveted the left together so it may tighten up a bit but im not sure. Nice job BTW.
