So nailing up the lower skins really getting a good fit of access / inspection covers. The cover thickness is greater than the joggle depth, so it sits appears proud of skin slightly.
I did not screw then down but seems so?
Question is this normal cover fit for RV-7???
BTW FYI mine is an early RV-7 kit? Did they make a change here? May be Van made the joggle deeper. My first RV build (RV-6) I recall there was a doubler around the wing skin cutout, where the nut plates went. The cover was same thickness as the wing skin, so nice flush fit, nominal gap. With RV-6 joggle you have a little gap all around for bend radius.
