Vans specifications state the ceiling of the 6 with 160 hp is 21,500'.
For the benefit of others, I was hoping you could describe in more detail exactly what happened and how you got in the situation you did. You said you were not holding enough right rudder. I've never been able to get any airplane to enter and maintain a spin without nearly full pro-spin rudder held in...but then I never tried to spin the RV from a full power entry with no rudder. Which direction were you spinning? I assume left, if you say it was a result of not enough right rudder? So you were spinning at full power with no left rudder being held? You must have had the stick very far back to produce a stall. I assume you then reduced power and unloaded the stick at some point. Did you reduce power before or after you unloaded the stick? Or did you unload the stick before applying anti-spin rudder? If you unloaded the stick first before stopping the spin with power in (or off even), you'd have pretty much been in a continuous downward snap roll, possibly with airspeed and stress building if power was not pulled. Probably would have been very disconcerting if you didn't recognize what was happening. 5000' is a huge altitude loss for a plane like an RV. Just curious if you had any additional insights or understanding after the fact exactly what inputs caused this, and what inputs may have delayed the recovery to such an extent. Thanks
My guess is he got himself into a spin, panicked, held full aft stick for a long time. So, either he didn't lose 5000', or he spun for 5000', which would mean he did dozens of turns.
Steve
