az_gila
Thank you...
...I found it in section 15 of my older, undated manual under "G-load testing" on page 44.
Hidden in the text is the aerobatic gross weight of 1375 pounds for +/- 6 G.
The same paragraph also stated that the negative G limit is -6, but it was not necessary to flight test to that number....![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The section also answered the previous post with this definition...
By, definition, maneuvering speed is the maximum speed at which full and abrupt controls can be applied. It is also the minimum speed at which limit G-load can be produced.
The speed does apply to all control deflections according to this definition.
Again, I do not know the date of this version of the manual (I have several later versions too...)
My manual is dated on the bottom of each page as follows.
6515.DOC 5/22/97, page 15-17
