The glareshield is aluminum.Hi, I am the owner( not builder) of a 2000 RV 6 tipper. Is the glare shield made of fibreglass ? I’m looking at installing a Garmin aera 660, ON the panel but under the glareshield & don’t want to install an antenna if possible. Regards![]()
I have a Garmin aera 660 in an Air Gizmos mount in the panel of my 9A. I have no problem with satellite reception. Try it without an external antenna. You probably won't need one.Hi, I am the owner( not builder) of a 2000 RV 6 tipper. Is the glare shield made of fibreglass ? I’m looking at installing a Garmin aera 660, ON the panel but under the glareshield & don’t want to install an antenna if possible. Regards![]()
Python,Hi, I am the owner( not builder) of a 2000 RV 6 tipper. Is the glare shield made of fibreglass ? I’m looking at installing a Garmin aera 660, ON the panel but under the glareshield & don’t want to install an antenna if possible. Regards![]()
What Kyle said. Here's a pic of my set-up, just clears the top cowl. WAAS GPS driving ADS-B, barely showing beyond that it is a second remote GPS ant. for the handheld
What Kyle said. Here's a pic of my set-up, just clears the top cowl. WAAS GPS driving ADS-B, barely showing beyond that it is a second remote GPS ant. for the handheld.
View attachment 82264Hi , so obviously no issues with heat from the engine ? This is under the cowl right ? Cheers![]()
