Rv 4 manual aileron diagram
peert70
Active Member
Patron
Does anyone have this kit or diagram in kit for aileron trim.I could probably make it from scratch but would be nice to have diagram in kit.Currently not available at vans.Plan to use on Harmon that flys straight but would be nice to trim out minor changes as weight and speed change.
I don’t have what you’re looking for but I’m gonna be “that guy” for a moment.
Strongly consider the spring bias system adapted to Rockets from the RV8 as an option. This assumes there’s gaps in the existing installed equipment but there’s a lot of longitudinal places it could be added. You wouldn’t have to mod an aileron or work through an access panel to install the actuator. Search the Rocket section if interested. Another option. Just sayin’.
Change fuel tanks every now and then. If you have a consistent heavy wing, check rigging or experiment with a little wedge under the aileron. Install with double sided tape until happy, the rivet with a few blind rivets.
