Chris Beebe
Member
Hello everyone, I'm new to the rv world and just picked up a rv-3 that needs the wing repaired. I had a collapsed rib and had to remove four feet of the top skin that was damaged. I'm getting ready to rivet the skin back down and wondering what the best method is for accomplishing the task. As far as bucking the rivets is it easier to work the leading edge to the trailing edge or work the center of the wing and work to the root? Any info would be great. At this point it almost looks like I would need to cut in an inspection access hole but clearly there was not one to start with.
Thanks.
Thanks.
