I spoke with Brian about several things. As Louise said the GW is planned for 2400lbs. He wouldn't commit on the empty weight because they don't know yet. They are committed to having the ability for customers to install floats but it gets tricky. The more structure you add the heavier the fuselage gets. I believe they are trying to hit a compromise with some of the structure needed for floats part of the standard design but a float package that would add additional parts, and weight. I tried to get a ball park empty weight and threw out 1400 to 1500lbs. He came back quickly with it will definitely be below 1500lbs. I didn't ask about the nose wheel option but I'm sure they are also deep into how that will work without a major redo to the fuselage design.Rian Johnson said the gross will be 2400# and the empty "will depend on how you build it."
I aslo mentioned the kit and plans OA were very well done. My 2 suggestions have been mentioned on this site many times. Pre bend the flap trailing edge to the final shape and either don't dimple the leading edge of the horizontal stab or dimple and break the edge in the factory. He said the flap bend is already taken care of on new kits and understands the challenge on the horizontal stab. No commitment on that one but leaning towards doing both in house.
