The VS went together just as easily. I was a little confused reading the instructions ahead of time, but once you have the parts, it all lines up nicely. The long, thin rear spar caps (two of them) have a bend to them, but straighten out once installed.
The KAIs did not call out for any fluting on the ribs, but there is some curvature and warped metal, so it made sense to lightly flute the main rib and nose rib flanges.
It was almost silly how easily all this went together. Kudos to the engineers and manufacturing folks at Van's.
There are many different sizes of solid rivets used, and again, I found it easier to just buck the rivets rather than repeatedly adjust and test the squeezer. YMMV.
