RV-14A Legs
Doug Rohrer
I am at the point of inserting the big flat gear legs into the fuse on my -14A. The fuse is still on a rotisserie so I have fairly good access to both sides. I cannot get the gear leg to go far enough into steel bracketry inside the skin to even begin to get the first bolt inserted. I tried putting a little grease on the black coating on the gear leg, but I still cannot force it in far enough. Has anyone else had this problem? I don't want to use the big hammer solution.
The legs have a thin layer of some kind of soft material right where it goes into the fuse brackets. I assume it is needed to avoid steel/steel contact when the gear leg flexes, but it seems that is what is jamming things up. I will call Van's tomorrow to see what they say.
Many builders have had to remove not only powdercoat but some steel: I just gradually worked the bulging part of the bend (using scotchbrite wheel - some just use files) until it fit. (My method very slow but I felt more comfortable that way and the surface stayed nice and smooth).
Covered well by "E" here:
https://rv-14a.blogspot.com/search?q=gear+leg
Thanks guys. I just had to grind a little powder coat and some steel off the legs and then they could be persuaded to go in. Vans builder support says this is very common.
