Hello All,
I'm fitting my top cowling laterally per page 45-08 using the dual plum bob technique described in the plans. The cowling was trimmed to the scribe lines around the inlets and spinner opening and fits nicely with the trimmed bottom cowling. I'm using a clear Plexiglas spinner template in place of the actual prop and spinner bulkhead. I can cleco the cowling to the template and the 3/16" spinner gap is built in. I haven't yet drilled the cleco holes in the cowling.
My issue is getting the top cowling within the 1/16" tolerance laterally (in roll) that Vans directs. Mine is about 5/16" off between sides when measured from several spots on each side of the cowling front to the floor. The floor is level. There's no amount of moving the aft edge of the cowling left/right per plans that will reduce that difference significantly without severely distorting the cowling.
Has anyone else seen this amount of variation between top cowling sides? If so, how did you deal with it? If I accept the 5/16" difference what problems, if any, am I creating with baffling, inlet ramps, appearance, etc.? I'm trying to figure out if this is a big deal or not and how to fix it. Van's specified a 1/16" max difference for a reason.
Thanks all for your time and any advice.
Scott Davis
Scott Davis
