Today when I turned on the landing light (everything else was on), the engine monitor screen BAT AMPS display started blinking red. The ALT AMPS remained about 9, and the system voltage was 13.9. The BAT AMPS would blink whether the engine was idling on the ground or at cruise power in the air, when I turned on the landing light.
At 12 hrs I'm still learning the systems. I'm very old-school, steam-gauge, etc. -- accustomed to a single ammeter on an aircraft, showing whether current is going into or out of the battery.
What is the BAT AMPS measuring? Is this discharge from the battery? And if so, why would there be a discharge? Where is this sensed? What kind of fault could be producing this display? What tests should I make? What can I do to correct this?
