RV-12 rudder lock
farmerrd
I'm New Here
RV12 Friends,
Have any of you devised a simple rudder control lock? I am trying to fit Van's tow bar/control lock per their instructions without much success. I am convinced there must be a better, simpler way to lock the rudder. Any suggestions would be helpful. I am sure that in a strong(not even very strong) the rudder would suffer. Thanks Rod Daulton
Here is one idea. Do a search and you will find others.
Made from 1" PVC.
For me the tow bar works great. Light and small. Benefit is that it also works as a parking brake.
From what I remember is that when I drilled the first holes in the tow bar the fit wasn't perfect. By rotating the tubes 180* you will have another change.
If you make it so that it rests against the upper part of the rudder pedals, would it double as a "sort of" parking brake?
It is supposed to press on the upper part. If you make it correct it pushes both brakes. Works great and is really a good tow bar.
(add a picture next week)
I meant Tony's rudder lock, not the Van's tow bar. My other unasked question would have been whether it's a good thing or not to leave pressure on the brakes by doing that, but if the Van's tow bar does it, well, unasked but still answered. :)
I used a standard available parking brake, it holds pressure against the wheel cylinders, but NOT the masters. Maybe a little less prone to leaking failure I thought..
If on Tony's design, you inserted a coupler (not glued) on the long piece back to the seat pan, you could have 2 lengths of pvc aft of it ready choose to either connect it to the pedals as shown or up to the brakes, using the longer piece. I think I'll do that! The towbar solution is kind of awkward, but then again I usually carry the towbar with me anyway. The pvc will be an extra pound or so.
