I recently installed the AERA 550 in place of the 496 as it is discontinued. The installation is straight forward. Cut hole 6.5" X 4.25" . Make two strips 1" X 4.50" .040 aluminum. Rivet strips using four holes in panel mount. Strips are for mounting Gizmo. You must use Gizmo to turn 550 on and off. Order wiring harness for AERA with nine pin connector. Plug in. Done. I chose the 550 because I am not using XM. Got a better source and cheaper.
Ron Russ
Avenger V, RV9A, RV12
Ron Russ
