It has been a very cold and windy winter in Iowa. Got 2nd tank mod & vent done, and able to fly again. Smooth, but temps were not too bad. About 18F on the ground.
Are you guys referring to the dog slippage check where the large torque is required? If so does anybody know what the up side is to doing it? When I was at the ROTAX IRMT course the instructor said it was to ensure the dogs will slip in the event of a prop strike to protect the engine. If that is really all it accomplishes I don't think it's worth the time and expense to me. Does anybody have any insight on the value of this check?
a good time to look at bearings and gears also. Basically, if you break the prop, you likely will have many things to work on. I'd think you would want to check the crank if you had such an event anyway. Not sure it is that expensive to have done by an authorized service center.
my EAA chapter asked me to be the chapter "fly-out" coordinator. It gives me even more places to go and enjoy. Usually stay within 150 miles of my airport. Still enjoy flying this great little plane. Economical and good enough speed to get you there. That is the reason for this thread each 100 hours. Hope it inspires those building to keep working.
