RV-12 Idle speed
Hansgiant
Member
Hello 12'ers
I recently had my carbs balanced which has made a huge difference to performance. However when pulling the power on landing my Idle speed is now 1900-2000 rpm.
What should it be? what is your idle speed with throttle closed?
Thanks a bunch
Hans
Van's recommends setting the idle at 1650 RPM. However, when sitting on the ground, you should idle above 1800. The Skyview will give you a warning below 1800.
There was a recent discussion about idle speed in THIS THREAD
If you do not want to read the whole thread, at least read post 33.
Van's Aircraft specifies on page 12-14 of the "RV-12 MAINTENANCE MANUAL" dated 08/12/13, "VERIFY THE IDLE SPEED AND ADJUST AS NECESSARY TO ACHIEVE 1600-1650 RPM AND SMOOTH ENGINE OPERATION".
The manual does not state the engine temperature, but according to a Van's employee, that idle RPM setting is at full operating temperature. If you want to make very short landings, a lower idle RPM will help.
Joe Gores
Hello 12'ers
Thanks a bunch
Hans
Are you talking about idle speed while on final at normal approach speed? Or is this your idle speed on the ground?
Idle speed on the ground will be very different from in the air on approach. Depending on your nose down attitude rpm on approach may be 300-400 rpm higher than idle sitting on the ground.
Interesting that so many RV12 pilots want a "correct" RPM speed on approach while refusing to fly a low airspeed. As Van's will tell you, a 50-55 kt final approach speed works great for landing with minimal float. That said, many, many RV12 pilots refuse to fly below 60-65 kts (or higher). Why is that? In most aircraft, approach airspeed can be managed very successfully with pitch. Who flies an approach by RPM?
I don't think the OP was trying to fly the approach by RPM, it was just a question regarding where the idle speed was being measured. I know the last thing I'm worried about is what the RPM is on final.
You are sure right about the fact that most probably don't slow the aircraft down as much as they should. I was sure guilty of that for some time. The reason is that I was used to flying the other RV aircraft at 60-65 kts and old habits are hard to break. The challenge I face on every landing is getting the altitude and airspeed nailed on final so I can keep the airspeed at 55 kts. The airplane doesn't want to slow down and if you are the least bit high, the only option is to lower the nose and pick up speed.
The RV-12 lands much nicer at 50 kts than 60 kts so I try real hard to hit that number. However our field is surrounded by trees and a ridge line off one end and it's only 2100' long, which calls for a little steeper approach than typical.
Actually the way to get it to come down faster is to raise the nose and get slower.
As already mentioned, if the IAS is much above 50 Kts starting the round out for the flair, the airplane will be floating quite a ways down the runway, so I shoot for that unless I am making a landing at rather high weight.
I don't fly the entire final approach that slow though. I usually progressively loose airspeed from the point on downwind abeam the touchdown point so that I don't bog down traffic flow in the pattern, and then turn final at ~ 60 kts. If I find my self high on final, I slow to 50 kts much earlier, that will accelerate the rate of decent. If that is not enough, I add a bit of fwd slip to help.
Usually pilots land into the wind. Slowing down takes longer to get to the runway and gives the wind more time to act on the aircraft. I do not look at the airspeed. I watch the AOA. If trying to land as short as possible, I keep the AOA in the yellow just below the red. If the computer voice yells "STALL", I relax the back pressure slightly. Below is a quote from the RV-12 Pilot's Operating Handbook.
Joe Gores
Diving the aircraft in an attempt to lose altitude when flying into a headwind will only increase the required landing distance.
Yep, I kind of opened myself up for that one. What I should have articulated better is more of a local condition specific for our field. If you get too slow in final, the swirling winds off the ridge line can cause your airspeed to drop very quickly so we tend to not get too slow on final to account for this. Once over the ridge, you can slip it but that builds up speed pretty quickly and the ridge is close to the end of the runway too.
I'm really not a bad pilot. Really. :D
RV-12iS Idle RPM Fluctuation
I recently noticed my RV-12iS (about 40 hrs TT) exhibit RPM fluctuations with engine at idle (app. 2,000 RPM)
This happens during descent with throttle at idle or taxiing back to the hangar after the flight.
The RPMs will fluctuate in a consistent and regular cycle from 1,900 to 2,100. It will climb to 2,100, drop to 1,900 and then continually repeat.
Is this normal?
Is this normal?
Not normal. That sounds something like an intake manifold leak.
Flight idle will be higher than ground idle due to having forward speed so if your ground idle lowest rpm is 1650 your going to see 1900-2000, if not a little more flying the pattern with throttle at idle. I like to pull throttle when abeam the numbers and see if I can land without touching the throttle, good practice for engine out.
