RV-12 ICAO Code
RV12Pilot
Member
I have the classic Dynon Skyview in my RV-12. Which ICAO Code(s) should I use to identify myself for flight following purposes? Thank you.
For flight following just identify yourself as an RV-12 to the controller. If you are an ELSA you are required by your operating limits to also state you are an experimental RV-12.
If you are looking for the codes to put in the ICAO flight plan,
1800wxbrief.com
planning section will help you find the correct codes.
