Geico266
I jumped the panel with 12v to see where I was at with the trim servo as reported by other. Much to my surprise the fuel pump was on..... and there is no switch. Pull the fuse?....................the electronic cooling fans stop.
Either the rest of you guys have not hooked the boost pump up yet. There is no way to shut it off! Sure would be nice to be able to shut the boost pump off to work on the avionics.
Why am I the first to figure this out? This really scares me!
Can someone else double check me on this? Pull the fuse to the fuel pump and the fans stop? Why?
