I need some help. First, I built my RV-12 with the Dynon D100 EFIS and a Dynon D10 EMS. I just installed the Dynon autopilot and AP74. When I do the DSAB configuration everything is identified and active. The Servo calibration says it was successful. Now the problem. When I do the Servo Test it does not go all the way to pitch up and roll right. It moves in that direction but not all the way. I then pressed NO and start over with the Servo Calibration. The Servo Test still does not maker a full travel to pitch up and right roll. For the heck of it I pressed YES on that test and the Servo's should go to pitch down and roll left. It does not. It goes to pitch down and roll right. But not all the way in that direction. What am I doing wrong? Is it a linkage length adjustment? When I'm out of the test mode the AP:OFF-OFF appears in the lower right of the D100 and I can turn on the HDG and ALT and the servos move when I move the heading bug. I hope I gave someone enought information as to what I'm seeing. Thanks!
