There have been a few posts here and there about the RV-12 as a taildragger. I think that this discussion deserves just a little more attention.
First, most LSAs will probably fly out of small strips, many of which will probably be grass. Nothing works better on a grass runway than good old fashioned taildragger and nobody does it better than Van. Just like the RV-9, Van is reluctant to put the R & D into a project unless he sees a high interest and potential for increasing kit sales.
The RV-12 needs to be offered as a taildragger!
Some of the comments that I have seen of this site suggest that the 12 would be difficult to convert to a taildragger. One reason stated is that the mains are designed to be supported by the front spar and that a taildragger configuation would require engine mounted gear. I remmember when the old Tripacers were converted to Pacers. All they did was basically to reverse the gear legs, which canted the gear forward and now they were taildraggers.
Consider designing gear legs for the 12 that attached to the same point only were swept forward to the required position to shift the three point CG far enough aft to place adequite weight on the tail and relieve the weight from the nose. Now, all that would be needed is a tail wheel mounting and differential braking.
It is amaizing what a determined builder can come up with.
All comments appreciated. I think that we can make this a viable option for our RV-12s
Tom
Tom
