RV-10 Useful Load - G3X and AirConditioning
Brian B
Member
The RV-10 Usefull Load seems to be a moving target.
During a prebuy on a 2024 RV10, I had the aircraft weighed. The Empty Weight (Zero Fuel and full oil) was 1816#.
Status of the aircraft weighed. 2 G3X, Air Conditioning which is supposed to be 65# or less. 3 color Painted. Leather interior.
The POH provided originally said EW of 1630# which is 186# difference. Is it likely that paint, AC, and G3X could total to 186#?
Did it have a full luxury interior that was perhaps added after the initial W&B? That can add a lot.
All things being equal, probably not. More likely it's just a cumulative effect of a lot of little things or the original W & B was off. Paint will add a minimum of 25Lbs, while the G3X or any EFIS just adds a few pounds. Without knowing the exact config of the plane during the initial weighing, kinda hard (albeit not impossible) to piece it together.
1816 #’s seems heavy for that configuration you described.
See also: https://vansairforce.net/threads/basic-empty-weight.231483/
My RV-10 is about as light as any you'll find that have the standard Hartzell and a conventional battery. It weighs 1607 lbs including paint. It has one G3X and one G5.
If your aircraft started at 1630, paint and the A/C could easily add 100 lbs. The other 86? Well, depends on what they added when they added the G3X. It ain't just the screens - there are other goodies that go along with the system - Servos, AHRS, EMS, backup batteries, etc. Also, if they added carpet and interior that could easily account for the other 86 lbs.
No. Ac is around 65#s, I believe. G3x doesn’t weigh that much more than 6 pack instruments, maybe 5 pounds more at most, not including AP stuff. Paint on a 10 is around 25-30 pounds.
That is a heavy bird. My 10 is more spartan than many, but it is 1630 with paint and toolkit. I suspect most nicely equipped 10’s are in the 17-1750 range. Add ac to that and you get 1750-1800. So not terribly far off from a lot of 10’s. But it does take a sobering chunk out of your useful load if you plan to respect the vans GW number.
I suspect the 1630 was not an actual weight, but a spec from the rv10 brochure.
Thank you
Do you have the beefier Matco brakes / wheels? They are quite a bit heavier than the stock brakes. I still have both in my shelf, can weigh the difference.
Mine is 1840. I have a parachute and AC plus a nice interior. Went in with eyes wide open on a heavy plane, it's really for three people and anything you would ever want to haul or 4 people and handbags. Wife loves it which is all that matters for us.
How much does your parachute weigh?
Well said. Its all about personal choices.
