First time builder and poster here just getting started on my RV-10, so I basically know nothing.
I bought a full kit secondhand with some of the surfaces finished, but was halted due to LCP. I'm in the process of replacing/rebuilding the affected components and immediately screwed up the trim tab skins. I have the original perfectly built trim tabs with the LCP main rib in them and experimented with seeing if I could get the main rib out without hurting the skins. I was successful and would like to use these skins with the replacement spar. This will allow me to use the solid rivets on the accessible portion, but I would need to find an acceptable pull rivet in place of the AN426AD3-3.5. What would you folks recommend as an acceptable pull rivet?
Thanks, Garrett
Thanks, Garrett
