Today I began trimming the cabin cover to fit on the fuselage. After trimming to the scribe lines, the dimension between the edges of the door pillars is 37-7/16", approximately.
The dimension between the aluminum frames forward and aft of the doors is approximately 37". Looking at the cabin cover, in order to cut it to 37", it would require cutting almost the entirety of the straight/flat vertical fiberglass parts of the door frames out and leaving only the curved parts. This would take out a significant portion of the reinforced areas where the door latch pins will go.
This doesn't seem to be right. Can anyone compare their experiences with mine?
