AboveMSL
Greetings,
I just completed the rudder and I think it turned out well. The trailing edge is quite straight (no waviness), however, if I drop a plumb line from the top of the rudder, down the aft side along the trailing edge, the bottom is not in line with the top. The plumb line falls to the left of the trailing edge by approximately a half inch at the very bottom. Have I somehow twisted things or is this how it should it be?
(As a note, I used very little weight right along the trailing edge to hold it down while I back riveted the trailing edge together.)
Greg
Greg
