Davepar
Fitting the empennage to my RV-7A fuselage has been going very well until today. I fitted the new-style rudder, and installed the rudder stops that I carefully fabricated. The rudder bearings were all set to the recommended starting point. Instead of 1-1/8" of clearance between the rudder and elevators, it was more like 1/8". And the rudder swung much further than 35 degrees.
I searched through the old Yahoo Groups RV-7 archives. There was a thread about this a while back. It seems that some builders have no problem and others do. Is there any new info on this problem?
I tried cranking in the bottom bearing. It's now in quite a bit, 29/32", from the recommended starting point, 1-1/16". The gap is now better, but still only 1/2". There's not much more I crank in the bottom bearing. There are only a few more threads exposed.
Here's the current state:
Should I keep cranking in the bearings, or just make new rudder stops?
Dave
![IMG_4170.jpg](/proxy.php?image=http%3A%2F%2Fwww.dualrudder.com%2Falbums%2Frv7%2Fimages%2FIMG_4170.jpg&hash=2b394e3c7af95645e794df63659fe43d)
![IMG_2571.jpg](/proxy.php?image=http%3A%2F%2Fwww.dualrudder.com%2Falbums%2Frv7%2Fimages%2FIMG_2571.jpg&hash=08f15489899d9abfe1b0deba1bb0fa69)
![IMG_2572.jpg](/proxy.php?image=http%3A%2F%2Fwww.dualrudder.com%2Falbums%2Frv7%2Fimages%2FIMG_2572.jpg&hash=657d830f868052a7951ad36c1669a844)
![IMG_2573.jpg](/proxy.php?image=http%3A%2F%2Fwww.dualrudder.com%2Falbums%2Frv7%2Fimages%2FIMG_2573.jpg&hash=466384547b9cdd8062af645ad6da718c)
Dave
