BillL
Well, I purchased an RV7 in process, bought tools, build shop, made the practice kit, and now have a question about the rudder stiffeners. The dwg says to cut the taper on the angle flange between these little notches. The line of intersection apparently needs to go through the imaginary centerpoint.
Well, most notches are on the corners which will be rounded out anyway, but the taper has one on the outeredge of the flange.
Do I leave the notch or round out the taper to eliminate it? The notch seems like a stress riser to me? Engineers don't like notches.
OK, I know you guys are way past this, but please help anyway.
Bill
Bill
