Am about to install my ground adjustable rudder pedals (-8) and have found that there is some clearance issues with the independent brake reservoirs hitting the firewall when the rudder pedals are mounted on the full forward position. The solution is pretty straightforward....just mount them farther back. My question is this......what kind of rudder pedal travel distance should I plan for once they are installed and connected to the rudder?
Anyone have a idea? Thanks in advance!
