RSA-5A Exploded View / Schematic
Saccharine_Lilly
I'm New Here
Hello,
Thank you in advance to all of you who will read this and I hope help...
We have a throttle body (RSA-5A) that has had the diaphragm replaced. It is now hesitating when we put more fuel. We are hesitant about the order it was put back together (order or washer and so on) because when the original was opened everything fell to thw floor.
Would someone that a microfiche / exploded view / schematic for the RSA-5A throttle body diaphragm installation?
Thanks again.
I cant help you with the schematic. However, if you find you should send the fuel servo out for service Airflow Performance in Greenville, SC is the shop I use. They will fix it right. Build up that relationship.
