plbarrett2004
Active Member
Hello all,
I've now seen some odd behavior by my prop/ governor on two occasions. The first time during some climb and range testing I noticed that if I was cruising with a lower RPM, say 1900, and low MP, say 20", that placing the condition lever full forward did not result in full RPM. As I would bring MP forward RPM would increase, but behind MP, and not to its full amount. To the extent that I would have to be careful not to go too far over square. I found that given a little time and airspeed variation the prop would eventually get back to normal RPM.
The second time today, I was cruising at 21" and 1900 RPM for a good bit. Then I started a descent and return to my home airport. It was a slow decent and I kept the cruise settings the same. Upon reaching pattern altitude, I brought the prop forward, but no real response. I played with bringing MP forward to "tow" the RPM with it, but no real success. At this point I was on downwind, so it was time for fuel pump, prop and mixture full forward, get setup for landing. But I was keeping an eye on the RPM. It still seemed low. As I landed and brought power forward for a touch and go, RPM was still lagging. I "think" I felt a difference, but in the moment that might have been my hypersensitivity. I quick glance at the gauge showed me going super high on MP while RPM was still way lower than it should be, despite the lever being full forward. Not wanting to run massively over square - I pulled the MP back and aborted the touch and go.
Quick triage shows all of the connections to be appropriate. Any thoughts on what could be causing this? I have been having slightly low oil pressure (detailed in another post) but I don't see a connection.
Attached is the engine data showing MP and RPM. Near the end what isn't show is when go full forward on the condition lever, but it occurs just prior to the MP going up.
Thanks!
Thanks!
